BPDU问题一例
问题描述:
%Mar 28 22:52:07:228 2019 楼层汇聚交换机13.202 STP/4/STP_DISPUTE: -Slot=2; Instance 1's port GigabitEthernet2/0/1 received an inferior BPDU from a designated port which is in forwarding or learning state.
[楼层汇聚交换机13.202] dis stp ab
[楼层汇聚交换机13.202]dis stp abnormal-port ? > Redirect it to a file >> Redirect it to a file in append mode | Matching output <cr>
[楼层汇聚交换机13.202]dis stp abnormal-port ---[GigabitEthernet2/0/1]--- MST ID BlockReason Time 0 Disputed 22:53:36 03/28/2019 0 Disputed 22:53:34 03/28/2019 0 Disputed 22:53:32 03/28/2019 1 Disputed 22:53:36 03/28/2019 1 Disputed 22:53:34 03/28/2019 1 Disputed 22:53:32 03/28/2019 3 Disputed 01:50:58 01/07/2013 3 Disputed 01:50:56 01/07/2013 3 Disputed 01:50:54 01/07/2013
请问 inferior BPDU  这个是什么BPDU
解答:
received an inferior BPDU含义为是交换机上收到低优先级的BPDU,同时该BPDU携带learning或forwarding标志,即认为自己为根端口;查看abnormal-port时发现该端口被disputed,该功能是保护根桥,防止下层网络震荡,一般产生原因为链路单通,对端收不到根桥发送的BPDU报文,从而对端一直发送低优先级的BPDU
出现这样的情况,通常确认当前的网络环境以防止攻击。比如网络是否发生变动,是否接入了其他带生成树协议的设备,可以通过拔插端口,逐个端口抓包,看是否存在非根桥发的BPDU
收到了低优先级的BPDU,会造成根桥抢占,造成网络中STP树波动,可能是新接了交换机,mac地址较小,也可能是有恶意攻击。
优化的话,网络中配置根桥,配置根保护;接用户的端口开启edge-port等
 0  已被阅读了6057次  楼主 2023-05-15 12:04:04
回复:BPDU问题一例
Your IP: 18.97.14.86 , 2026-11-18 16:56:25 , Processed in 0.54921 second(s).
