<华为>某公司网络配置分享
拓扑结构如下图:
相关配置:
核心路由器
vlan batch 100 200 300 400
#设置Http管理允许所有端口访问
http secure-server server-source -i all
#创建Vlan
vlan 100
 description BanGong
vlan 200
 description Manager
vlan 300
 description JianKong
vlan 400
 description Guest_Wifi
#创建Vlan接口地址
interface Vlanif1
 ip address 192.168.0.1 255.255.255.0
 dhcp select interface
 dhcp server dns-list 192.168.0.1
interface Vlanif100
 ip address 10.2.42.1 255.255.255.0
 dhcp server excluded-ip-address 10.2.42.16
 dhcp server dns-list 114.114.114.114 202.103.224.68
interface Vlanif200
 ip address 192.168.10.1 255.255.255.0
 dhcp server excluded-ip-address 192.168.10.2 192.168.10.7
interface Vlanif300
 ip address 192.168.20.1 255.255.255.0
interface Vlanif400
 ip address 192.168.100.1 255.255.255.0
#设置接口信息
interface GigabitEthernet0/0/1
 description To:AC_KongZhiQi
 port link-type trunk
 port trunk allow-pass vlan 100 200 300 400
interface GigabitEthernet0/0/2
 description To:JianKong
 port link-type access
 port default vlan 300
interface GigabitEthernet0/0/4
 port default vlan 100
interface GigabitEthernet0/0/6
interface GigabitEthernet0/0/8
 description To:JieRuJiaoHuanJi
 undo port trunk allow-pass vlan 1
interface GigabitEthernet0/0/9
 description Zhuanxian
 ip address 10.2.0.165 255.255.255.0
interface GigabitEthernet0/0/10
 description Internet
 nat outbound 2999
 ip address dhcp-alloc
#设置对应的出口路由
ip route-static 0.0.0.0 0.0.0.0 GigabitEthernet0/0/10 192.168.1.1 description Internet
ip route-static 10.0.0.0 255.0.0.0 GigabitEthernet0/0/9 10.2.0.166 description ZhuanXian
接入交换机
#设置Http管理允许所有端口访问
#创建管理Vlan,并设置地址
interface Vlanif200
 ip address 192.168.10.2 255.255.255.0
#设置端口
#设置上联端口为Trunk
interface GigabitEthernet0/0/47
#回程路由
ip route-static 0.0.0.0 0.0.0.0 192.168.10.1
AP交换机
#设置Http管理允许所有端口访问
#设置管理Vlan及地址
interface Vlanif200
 ip address 192.168.10.7 255.255.255.0
#设置端口为trunk,放行多个Vlan,同时设置默认Vlan
 port trunk pvid vlan 200
 port trunk allow-pass vlan 100 200 400
#设置上联端口为Trunk
#回程路由
AC控制器
#设置Http管理允许所有端口访问
#设置管理Vlan及地址
interface Vlanif200
 ip address 192.168.10.6 255.255.255.0
#上联口设置Trunk
interface XGigabitEthernet0/0/1
#设置ap的通讯Vlan及密码
capwap source interface vlanif200
capwap dtls psk xxxxx
capwap dtls inter-controller psk xxxxxx
capwap dtls no-auth enable
本文章最后由 admin 于 2022-10-30 19:36 编辑
 3  已被阅读了3525次  楼主 2022-10-30 19:16:49
回复:<华为>某公司网络配置分享
Your IP: 10.3.254.229 , 2026-11-17 09:45:06 , Processed in 0.57519 second(s).
